changing internet options
8 Mar 2007
between here and there
hey all,
I have several pc's that i have to set up. The main thing thats causeing me a headache is that i have to change loads of the options in internet options.
Stuff like, disable pop up blocker, enable active x downloads for signed and unsinged websites, allow auto running of active x scripts and such.
most of the changes are part of the scrollable options and require a simple tick in the box.
I also have to add a trusted site and set upa proxy for internet access (in lan settings)
my question.
Is there any way to automate this???
I think i know the answer as no, but i thought it was worth a pop. I have checked to see if iexplore.exe has any command line switches, which it doesn't.:mad:
Any ideas?
