changing key barrels around
Permabanned
23 May 2014
The key doesn't work on the drivers side door on the civic.
Would it be possible to swap the key barrels around from the boot to the drivers door? Or even the passenger door to the drivers door?
I have no idea on this specific model However!
In general you should be able to swap Drivers/Passengers side (Check with Honda dealer parts to see if part numbers are the same)
Boot/Tailgate locks are often completely different to door locks so I would not expect that you could do a swap (But again, you can check with Honda dealer parts!)
HTH
