changing motherboard question
31 Jan 2009
London
Is it as simple as changing it around, or do you have to get rid of the old drivers then put in the new MB followed by MB drivers?
Thanks
You can sometimes just change the motherboard and everything will work fine, but i always make a point of doing a format and clean install of windows if i change the motherboard.
Yeah, you can never really tell, always try removing all motherboard drivers - installing the now motherboard followed with the new drivers, and it might work.
But a fresh install is usually recommended
So far, I have never been able to swap a motherboard without a clean install of Windows. Sometimes you can get away with it if it the same chipset (P35 -> P35).
The main driver you need to remove is the HDD controller. With older IDE boards, you could just reset the driver back to a generic Windows controller, and then when you fit the new board, update it with the proper drivers. With newer SATA boards, it is much more difficult, but you can try it in the same method).
sounds best to do a clean isntall, gonna be a drag backing up everything:(
thanks
Backing everything up is a very good habit to get into. It truly gobsmacks me that so many students have their lives on their PCs and they're not backed up. And with USB hard drives being so cheap these days it just seems crazy.
Definately new install! Nearly lost a load of data! Good job I have several HD around so that I could do clean install then pull data from old HD then wipe that one!
