Just though id post how to change your pads for anyone wanting to or thinking about doing it
new pad time for me (well rear atm,ill update the thread with changing front pads when mine need doing)
first unbolt the caliper and remove the R retaining clip and retaining bolt and pull out the pads,then clean the exposed surface of the piston with a rag or brake cleaner/rag
then use a G clamp to compress the piston back into the caliper
next grease up the pivot pin on the caliper and a small smear of grease on the back of the pads to stop any brake squeal (take care not to get any grease or greasy fingerprints on the material side of the pads)
next install the pads/retaining pin and retaining R clip
mount the caliper back on the bike and tighten the retaining bolts and lastly pump the rear brake lever several times till it feels nice and firm
