changing my watercooling.
28 Nov 2004
im changing my custom watercooling for something smaller.
im buying a 2600k cpu moday and want to overclock it.
what would the best air cooler be or would this be better.
Corsair Hydro H70. i just want something small now so i have much more room in my case.
If you're going to get an H70, why not stick with your (far better) custom water-cooling. If youw ant something less compex get a Prolimatech or similar heatisnk and just use top-end air.
Yeah was really wanting to just go top end air i have been looking @ the thermalright venomouse X RT cooler.
i would stick with the custom
i have purchased a 2600k cpu and they dont need to be under water its a waste. they run much cooler thats why really prefer a air cooler.
anyways gone for the cheap and chearfull thermaltake frio cooler.
got rated best overall cooler in custompc magazine. will give it a go.
hope it fits my mobo.
that cooler does look good and does get some good review's.
im actually looking for a 2 fan cpu cooler and will investigate this cooler a bit more.
just one question,the red bars at the top,can they be taken of or are they just there for look's ?
