Changing permissions from a fedora13 boot usb stick
30 Mar 2010
Exile
Evening
I used to use ubuntu, but when i put my new system together I went for an ati graphics card. So now i cant get ubuntu to work. I've decided to use a fedora13 usb boot stick to access the 500gb worth of files I have on an ext3 partition, and i dont like using any of the ext-to-ntfs type programs. So I made the bootstick and it loads up fine but when i try to access some of the folders on my ext3 drive it says I dont have permission. On ubuntu you could change this either in the properties or by using 'sudo nautilus'. This doesnt work in fedora, is there another way? I dont want to install fedora, I just want to move the files off the ext3 and reformat the drive into ntfs.
Open a terminal, then navigate to the directory with your files in and run:
sudo chmod -R 777 *
This will wipe all permissions and allow you change whatever you wish.
Good luck!
When I try that I get this rather sarcastic message.
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
liveuser is not in the sudoers file. This incident will be reported.
You need to find out how out the password for the root user on the fedora live cd. Then type:
su -
and then
chmod -R 777 *
In the directory with your files as before.
