Changing the hard drive in a PS3 slim
21 Oct 2002
UK
Hi Folks,
I have a PS3 slim 120gb and I want to switch the HDD to a large one. One type of drive to I need, sata or ide. Also, what speed does it need to be?
Thanks
Matt
SATA 2.5"
5400rpm is 'safest' option
Make sure it fits as the higher capacity drives sometimes are a bit too tall to fit (cant remember the exact height - just check it fits in a PS3)
Remember to backup and sync trophies
If you have any further questions - do a search - this has come up a fair few times before ;)
ps3ud0 :cool:
Don't worry about putting in a SATA 7200rpm drive.
As long as it doesn't exceed 9.5mm height (e.g. 12.5mm) it will be fine.
Ahhh poop. Yeah, that's what I meant.. started writing a response then went back to change the wording and it came out wrong.
Have edited the post now :)
