- 10 May 2012
- North London
ok i have this cooler , and the fans that come with it are two x140mm .
http://www.overclockers.co.uk/showproduct.php?prodid=HS-009-PT&groupid=701&catid=2330&subcat=2348
And I was thinking about changing the fans that come with it for some 140 LED fans ...thing is....as the stock fans are " cut off " at the corner the fixing clips that come with it seem not to want to fit other 140mm fans that I've tried ie the clip gets a bit stretched ...almost like they are going to " pop off " from the cooler itself ....so if anyone has any recommendations for some fans that i could use please
thanx
thanx
