Hi,
Thinking of trying acrylic tubing just for a change. Currently have a standard flexible tubing setup which has served me well and still does. Having never tried acrylic, few Q's:
1) Which size tubing in terms of ease of bending (I am aware that flow is not so important on the tube thickness)?
2) Does fixed tubing leak more easily as less flexibility? I assume this is dependent on how well the ends fit into the fittings.
3) Are there major differences pros/cons of the various acrylic fittings?
4) Apart from tubing size, any else to look out for in getting the acrylic fittings?
Any other advice would be appreciated.
, These where all during instillation leak tests as they need to be very well aligned. a couple adjustments later and it's fine. Fixed tube doesn't like to move around too much though, prone to crack if jolted.
