Changing to ATI from NVidia
21 May 2007
A friend has donated his old HD5870 to me, to replace my slightly worn GTX280.
I have two versions of windows (on my windows machine anyway, which is where the card is going), XP and 7(64).
Assuming that it is not possible to re-install the operating systems (PARTICULARLY not the XP, which is my Studio OS and therefore simply can not be changed on pain of costing my a fortune)..........what steps should I take before/during/after swapping the cards.
I'm quite looking forward to trying this card as I have often been told that my opinion of ATI cards is wrong (I think they idle too hot, boot up with a black screen too often and have terrible windows drivers and non-existent Linux drivers), and nothing pleases the scientist in me more than being proved wrong.........I especially hope the ATI-ists are telling the truth about higher anti-aliasing with less effort...I play a lot of train and racing car sims, AA is essential.
I am assuming that a driver cleaning program is required prior to shutting down and swapping the cards.??????
Thanks for any help.
PS: If you're planning on posting "no, windows really IS as bad as you Linux users think it is, it literally cannot have its hardware changed without a re-install"......keep walking, because it's absolutely NOT going to happen ;)
PPS: Any advice regarding Ubuntu with this card would be gratefully received too, as I do like to maintain a working Linux on all my machines, even the windows ones......you never know when a second OS will save your bacon.
You don't really need driver sweeper/cleeaner for going Nvidia to AMD. I went from my 9800GTX+ to my 5850 on the same Windows 7 64-bit...it was very painless as all I needed to do was manual uninstall the Nvidia drivers under "uninstall a program", shutdown, swap the 9800GTX+ out with the 5850, reboot and then install the AMD drivers.
If it was upgrade from a AMD card, to even another AMD card nevermind a Nvidia card, people might need the driver sweeper at hand...
If possible removing drivers and software before you pull the card is always the best method but not essential.
Nice friend you have! Linux is third world to me, can't really help you there. Just uninstall the NVIDIA software, then install the AMD card and software. :)
Thanks all round chaps, just reporting back that there were no issues at all in the changeover, uninstall NV drivers, shut down, swap cards, start up, install CCC......and.....done ;)
I ran my rig with a pair of HD 7970s today for a while. All I had to do was leave the nvidia drivers on the machine and just install the AMD drivers no problem.
Unfortunately swaping back to nvidia, when I tried to enable sli the nvidia control panel told me to remove the AMD drivers first lol.
