Changing WC a little
24 Aug 2003
Gillingham Kent
Any compatability problems with these:
Tubing 1/2" ID - 3/4" OD XSPC Black Hose
Fittings1/4" BSPP - 1/2" ID - 3/4" OD Ghost Compression
Was going to use some Bitspower 1/4" BSPP Twin 45 and 90 Degree Rotary Fitting - Matte Black
Doesn't look like there'll be any problems. But when I used rotaries with barbs I had to get stubby barbs, otherwise the o-ring wouldn't compress and there'd be a leak. Not sure if it's the same with comp fittings.
There is that problem, when I was looking the rotaries were 4mm depth while the compressions were 5mm so worth double checking. Though my rotaries are Bitspwer too so you might be alright.
