Changing Y Splitter and Dual CPU Fan Fans ( Phantek )
27 Jan 2011
Afternoon guys, i am currently using http://www.overclockers.co.uk/showproduct.php?prodid=HS-012-PT
And would like to change the Y splitter and Fans to Red. To Match my AeroCool Strike-X Air case, Ram and every other periphal.
Any advice on decent quiet fans to accomodate this?
I am thinking of using one of these lot of choices.
YOUR BASKET
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99
1 x Corsair Air Series AF120 1500RPM LED Red Quiet Edition - Dual Pack (CO-9050016-RLED) £16.99
1 x Alpenföhn 120mm Wing Boost Plus PWM Fan - Red Clover Edition £12.95
1 x Zaward Golf III Fan 120mm PWM LED ZG3-120B - black/red £10.98
Total : £76.51 (includes shipping : £8.00).
I have ordered a black CPU y Cable as my current one for the phantec is white.
Have you thought about painting the fans you already have? its not actually that difficult if you have the patience to take the fan apart. Doesn't work out cheaper but you get to keep your good quality fans instead of trading down in performance to get the looks.
Me and painting really don't mix. Also i don't mind about losing minimal performance as i am using Open Air to house my rig. I have found a set of fans that are better power output in comparison but not available on OCUK.
