- 10 Feb 2011
Hi me again. If I set memory Dram timing SPD in the bios to quick then Channel interleaving and Rank interleaving enables but set to default auto when enabled. It says if enabled it can improve performance and stability in my bios manual. I have 4 sticks of ram at 8GB Corsair Vengeance Low Profile 8GB Kit. I have seen that if you have 2 or more sticks then its ok to enable it. Just wanted to double check. Thanks.
