Charging the iPod ?
19 Feb 2007
Sol
Hi peeps, just got a 64GB iPod touch as a present from my family (huge grin) and im just wondering as i dont have a pc or mac, unless i go to my brothers, can i plug this in to my PS3 at home to charge it ?
Try it and see what happens, It will most likely work.
How are you planning on putting music on it without a PC? (Surely you won't be buying all new songs off itunes?)
Or buy a Ipod charger which you can plug into wall. (AC?)
Mine is just a block which plugs into the wall. Then I have to put the USB cable into it - hook up itouch and I'm on my way to happiness again lol
