Charging Via Cigar Socket
7 Mar 2005
Swindon
Hi All
Hope this in the right place.
Can charging/using devices such as iPods and mobile phones via the cigar lighter socket damage the batteries in them?
Thanks for any info.
Rich
Richiev4 said:
Hi All
Rich
nope, otherwise you wouldn't be able to get car chargers :)
Only if you don't use the one that came with the device.
Using the charger from a cell phone for instance to run an iPod will most likely have an adverse effect on the iPod due to different voltages and current handling capabilities of the plugs.
