Chassis Intrusion!
26 Jan 2007
Leicester/The Toon
Hey Guys,
My Case, has a Chassis intrusion thing on it which connected to my mobo. Now I am not using this case and my Mobo (Asus P5LD2-VM-DH) is always coming up with "Chassis Intrusion", when I turn on.
I have been into the BIOS Manual there is nothing there for to disable it, at all. I heard people say put a cap or jumper whatever you would like to call it, on top of the pins.
What can I do?
- Matt
I'm not saying you're not looking hard enough, but the bottom of Page 1-31 in the manual shows you how to jumper the Chassis intrusion pins so it stays quiet.
As a matter of interest - have you tried overclocking that board as it looks to have a good range of overclocking features?
Thanks, i'll look for that :)
Ermm, overclocking isn't to good. It shows loads of Features for overclocking in the manual, but there actually in the BIOS. I just use the reset settings for overclocking, which takes my 3.4GHZ Pentium D, to 3.8GHZ with 900MHZ FSB.
-Matt
Spot of solder if you dont plan on using it again? Bend the pins together then add a drop of solder onto the top to keep them touching.
