Cheap 16gb Ryzen
14 Jul 2009
The best option is 3200mhz 8Packdark pro team group mems. These can run 3333c14 no issue on that board..
The kits you selected are ok. 2933 or so if you enable 2T command rate.
I appreciate the replies,
I've seen the 8Packdark mentioned all the time but was really hoping not to spend €200 plus on ram. The Vulcan above seems to be recommended in a lot of builds on here so was just curious about the above two or if there was anything else near that price range.
Would you know if they will run on MSI B350 tomahawk as well @3000 or 3200? They're not listed on supported memory list and I have 3000 corsair which doesn't go past 2666mhz.
Posted here unsure if you could help:
https://forums.overclockers.co.uk/t...use-errors-despite-not-being-faulty.18794165/
(Sorry to hijack thread)
The 8Pack dark pro is the best option for three reasons. Spd is programmed to work great with Ryzen even before last aegia update. Pcb is hi quality and the Ic is only Samsung b by far the most compatible and best overclocking ic around. Hence the cost.
