Cheap 4k 32 inch screen?
30 Jul 2005
Midlands
After a budget friendly 4k screen. I dont want ultra wide crap or curved crap. 16:9 ratio is best, and got to be 32inch or bigger.
Used for some gaming 60fps is fine by me.
Whats my options?
Currently on 32inch Samsung tv 1080p which is probably 10 years old
Sounds likie you know what spec you want already, I have had a few 32" Acer 4K screens and the IPS ones are pretty good, returned a TN panel as was a bit dull.
Best one I had was an XB321HK as had a proper g sync module if you can pick one up cheap used, only downside with it was the HDMI was only version 1.4 so no good for the new consoles, recently upgraded to a 27GN950.
Will probably wanna upgrade that 780 if you want to game at 4K (3070 or a used 1080Ti would be fine for 4K 60fps). You will want a monitor with g sync for nvidia cards or freesync for AMD cards.
Will keep an eye out.
Iv swapped my old tv a samsung le32b530 which is super pva panel to a newer samsung screen which is a pls panel and im shocked how much better it is in quality and its just a 1080p screen. Very impressive.
Just realized a 16:10 screen gives me more vertical screen space which will be better for work stuff. Also qhd rez of 1440p is sufficient for my needs since 4k may make everything a bit too tiny.
Need to explore more options but deffo want a 32incher
