I absolutely would not hesitate to buy from these againPanasonic's eBay account sells factory refurbs, £350 buys TX-40EX700B - perfect for console?
Because people aren't made of money? Thats like saying ' oh your brought a Ford Mondeo, I cant understand why you didnt spend more and get a Ford Mustang'i don't understand why you would pay £400 for a console then £350 for a tv. makes zero sense.
do yourself a favour and spend at least £1K on a tv.
OP I think at that price range most of the TVs are going to be the around the same level of performance, so go for whatever. I hear HiSense stuff is decent for the money so worth checking out some youtube reviews.
I bought a 55inch hisense 4k and its been brilliant, cant fault it and AV forums gave it great reviews.
not all tv's are built the same even by the same manufacturer. for example hisense have made a handful of great tv's but the majority are poor but they are cheap which makes up for that fact.
same goes for the likes of samsung they have crap tv's and good ones. you cannot say manufacturer X is who to buy from. you need to be specific with models. which goes back to the point earlier made about a ford mondeo being crap and nowhere near as good as a ford mustang even though they are both made by ford. but you usually need to pay more for better quality too.
What I'm saying is, my TV is close to his budget and has been absolutely bang on.
like i said previously. I cannot see the model being mentioned anywhere. there will likely be at least 3 different hisense models available of that size. possibly even more.
