Cheap as chips pre-built for old games?
7 May 2007
Scotland
Hey.... basically have no knowledge of building a Pc and my dad wants a pre built system for buttons lol..... His games library consists of need for speed games like underground 2 and the older most wanted along with half life 2, FEAR game types and was looking at buying a desktop Pc but open to laptop suggestions that would run these games at max settings?? Any suggestions guys... Cheers
Can't recommend pre built from anywhere except OcUK on here.
The 'Black Ops cyber warfare' (lol at the name :D) is on offer this week for £442. That should do the job for the games you mention.
I'd just get some chips if I'm honest, doubt you're gonna find a pre-built that cheap :p
Don't forget the salt & vinegar
Ah cheers for the input mate :) he's undecided whether to go the desktop route or laptop so hopefully have a few options to consider from peeps here.... He doesn't play many new titles n just stuck to these games plus os will prob be a copy of XP home
AMD A10 laptop will be fine, the integrated GPU will be fine for older games just don't go for a high resolution display, 1366 x 768 will be fine.
Would pref be played at 1920x1080 res for gaming as he has a 24" monitor so cud hook up a laptop or a tower..?
Yeah starting to look that way but not my money so just looking for best at lowest price for his needs :) al maybe throw in a pickle if the best deal pops up haha
There aren't any pre-build deals on here for peanuts tbh. You'd have to put it together yourself:
YOUR BASKET
1 x AMD A8-5600K Black Edition 3.60GHz (Socket FM2) APU Trinity Quad Core Processor (AD560KWOHJBOX) £79.99
1 x Gigabyte F2A55M-DS2 AMD A55 Chipset (Socket FM2) DDR3 Micro ATX Motherboard £49.99
1 x Antec VP350P 350W '80 Plus' Continuous Power Supply £32.99
1 x TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34096M1600HC11DC) £23.99
1 x Zalman T1 Mini Tower Case - Black £17.99
Total : £216.95 (includes shipping : £10.00).
and whatever other bits you need.
YOUR BASKET
You'll need faster RAM:
YOUR BASKET
2 x Patriot Viper 3 "Venom Red" 4GB DDR3 PC3-14900C9 1866MHz Single Module (P34G189UR) £20.99 (£41.98)
Total : £44.95 (includes shipping : £2.48).
YOUR BASKET
http://www.overclockers.co.uk/showproduct.php?prodid=MY-018-TG&groupid=701&catid=8&subcat=1387
Or this perhaps but yes Trinity will get you what you need for the cheapest cost.
A more expensive Intel route which will probably be more powerful than Trinity might be something like this:
YOUR BASKET
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
1 x MSI HD 7750 2048MB GDDR3 PCI-Express Graphics Card £71.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD £43.99
1 x Gigabyte H61MA-D2V Intel H61 (Socket 1155) DDR3 Motherboard £39.98
1 x Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046-UK) £39.95
1 x BitFenix Merc Alpha Gaming Case - Black £26.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
Total : £369.96 (includes shipping : £11.75).
A Pre-built system go for this:
http://www.overclockers.co.uk/showproduct.php?prodid=FS-040-OP&groupid=43&catid=2385&subcat=1798
Call up OcUK and ask them to put a dedicated GPU in there if you don't want to build yourself but it is pretty easy :)
The board does support 2133 RAM, you just need to enter 2133mhz into the BIOS and your done.
Also wouldn't buy a GDDR3 GPU :p
You referring to this one?
Just seen this on another website for £240.... Would this run the stated games at max settings?
AMD QUAD FX4-4100 (3.6GHz) & FAN
1-0G G640 DVi / HDMI/VGA Gaming Graphics
Asrock N68-VS3 Motherboard
8.0g DDR3 1333mhz
500g Sata III 7200 HDD
DVDRW DL +/-
Micro ATX Case Casecom CM-431
Branded 500W PSU
PCi Wifi 802.11b/g/n
Chances are 500W branded PSU means its a load of junk. The FX 4100 is one of the worst CPU's made within the last few years and god knows what that graphics is, chances are its onboard.
