Wondering if anyone had any advice on what platform to use.
The PC will be used just for streaming, basically encoding H.264 content.
I use OUYA for Steam streaming at the moment but its 100 mb LAN is meaning i can only play 1080 30fps really.
What would the best and cheapest solution for this? This doesnt have to be powerful at all, Would prefer passive. Needs to be Gigabyte Lan and AC Wifi would be good in the future.
Celeron J1900 custom build
Intel NUC
AMD A1 Kabini custom build.
The NUC looks good and i think the I3 would probably be overkill for what i need it for, Would the cheaper NUC's be any good? Would like to spend less than £250
Intel NUC
