Cheap build. Speck check.
14 Oct 2009
UK
Looking at building a few pc's for people.
They only want to be able to do internet, office, skype.
Build:
Intel Celeron Dual Core E3400 "LGA775" 2.60GHz (800FSB) - Retail £36.98
Seagate Barracuda 7200.12 250GB SATA-II 8MB Cache -
Biostar G31D-M7 Intel G31 (Socket 775) DDR2 Motherboard
OcUK Desk Manager Tower Case - Black
OcUK Swift 450W Silent Power Supply
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
Total : £142.39
I am sourcing the ram elsewhere in shape of 1gb sticks.
So will they be alright for what i need?
EDIT: Sorry for spelling mistake in title :(
Product Name Qty Price Line Total
MSI GF615M-P33 GeForce 6150SE (Socket AM3) DDR3 Motherboard £32.99
(£27.49) £32.99
(£27.49)
AMD Sempron 145 2.80GHz (Socket AM3) Processor - Retail £29.99
(£24.99) £29.99
(£24.99)
Seagate Barracuda 7200.12 250GB SATA-II 8MB Cache - OEM (ST3250318AS) £27.98
(£23.32) £27.98
(£23.32)
OCUK EZCool NA-705 Case - Black (500w PSU) £23.99
(£19.99) £23.99
(£19.99)
Corsair Value 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module (VS2GB1333D3) £21.98
(£18.32) £21.98
(£18.32)
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £13.19
(£10.99) £13.19
(£10.99)
Sub Total : £125.10
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.25
VAT is being charged at 20.00% VAT : £27.27
Total : £163.62
yeah should be ok with your spec if your using onboard graphics that psu should cope ok.
make sure you have a molex to sata power adaptor though as the psu only has 2 sata and 2 molex connectors on it (the product description is wrong) and they are on separate cables so if the optical drive is at the top and the hard drive at the bottom of the case you cant use the 2 sata power connectors to power both as they are on one cable and the 2 molex's are on the other.
i learnt it the hard way but had an ide optical and hd so had to get a sata to molex power adaptor which is more uncommon so had to order a few :(
