Another "spec me" thread I'm afraid. I'm after a cheap C2D build for my little brother.
All that is needed is a processor, motherboard and RAM. To give you some parameters; Around the 2GHz area with 2GB RAM should be plenty enough.
I have a GPU card and Hard Drive so no need to quote for those.
Cheers.
Cheers.
i think you could possibly save a few quid on the motherboard depending on you requirements
