Cheap CPU cooler for lga775
12 Dec 2005
I plan on overclocking my e6750. Nothing to heavy but want something better than the stock cooler.
Have around £10ish budget.
Cheers
Personally I would get the Alpenföhn Civetta because it uses pushpins to secure it to motherboard...same as stock cooler. Should be easier to install and won't even need to remove motherboard to fit backplate.
Other than that they look identical.
