Cheap dual SIM mobile phone for business use?
1 Nov 2007
England
I need a phone to use for my business. Ideally, it would be a dual SIM phone, and it would be quite cheap. Having said that I'd like 64GB of storage, Wifi, NFC, Bluetooth and a fingerprint scanner. It would also be nice if it were supported with new Android releases for a few years, but I understand that the cheaper you go, the less likely this is going to happen. I do not care about camera quality. My main phone can handle that side of things.
What do other people use for their business mobile phones? I don't want anything flashy but it does need to last for quite a long time as I don't have much money.
Any advice would be appreciated.
What networks are the Sims on?
If I've of them can issue you an eSim, that opens a lot more doors than two physical sim slots.
The network doesn't matter. I only use PAYG for business so I can transfer to any network at any time.
Edit: But to answer the question. Currently on o2.
Nokia 5.3 seems to tick all your boxes.
Thanks for the recommendation. I've just watched a review of the Nokia and it looks really good. I didn't realise it had a microSD card slot as well as being a dual SIM phone. I like that a lot.
This is going to be an expensive month though. Buying a new phone and a printer. *sigh*
Edit: Oh. I'm open to other recommendations still. Always good to have some choice. I know nothing about Android phones (I'm still running a OnePlus 6 as my main mobile phone) so would appreciate a bit of help from the more knowledgable members here.
I just checked and the Poco X3 is dual sim. It's the big name in lower-end devices right now.
I just watched a review of that phone. Looks good. Having a 120Hz screen though seems a bit overkill for using banking apps, authy, Firefox and calls and SMS though.
It's definitely overkill, but I'm sure it would stand in as a more than adequate main phone should something happen to your personal device.
I had a quick search and it seems like the OP6 is dual sim. You might even find the 120hz screen makes you want to use the X3 as a personal device and the OP for business.
