Cheap fix help needed for current HTPC
8 Nov 2006
Ireland/Northern Ireland Border
My HTPC started shutting itself down recently and I managed to diagnose the likely issue as the PC overheating. It seems the PSU fan has died.
The case I have is an Antec NSK1300 which I bought about 3 1/2 years ago so well outside any warranty.
I have two slots on the motherboard which are taken up by an ATI 5450 and a TV Tuner Card. I can't really remove either of them. The 5450 is passively cooled.
The processor is a low voltage Athlon 4400+ which doesn't generate much in the way of heat normally.
I don't really have much to spend on getting this back up properly. At the moment am running it with the case open which has stopped the shutdowns and dropped the temps.
I think I have no more than about £50 (maybe a little bit more) to "sticky plaster" this setup. I want to get a new HTPC later this year. Any suggestions on what I can do in the interim? (The PSU is a nonstandard one that came with the case. It can't take a standard PSU)
you could try and attach a fan to the outside of the psu blowing into the intake vents to push air through it ?
what size of fan does the psu have ?
*edit just looked up your case, you could cable tie a fan to your rear fan grill sucking air through the psu and as you are only using 2 of the 4 slots in the back of the case you could add one of these also to help pull some heat out the case - http://www.overclockers.co.uk/showproduct.php?prodid=SY-000-GE&groupid=701&catid=57&subcat=399
I had a PCI slot blower lying around I managed to squeeze in (just). Temps are OK so far but it is quiet noisy.
I will have to just endure it for a while!
Thanks guys.
If you careful you could open the PSU and replace the fan, I've done it successfully several times before. However I don't hold any responsibility for anything that happens to the PSU or you through possible mistakes (remember to unplug it and ground yourself :D)
Otherwise if you have £50 to fix the problem, why not buy a new PSU?
The PSU is a non standard size and there isn't space for a normal PSU.
Good thing you added that disclaimer. I'd have successfully been able to sue "that guy on the internet" otherwise!
Disclaimer: This is a common sense post. Don't sue.
Leave it unplugged for 24hrs then open. See if you are able to measure the fan diameter without touching anything electric.
For a replacement, I'd doubt you could go too far wrong with a Noctua fan, although I'm sure that when you get the dimensions of the fan people will spring up with advice!
Don't forget to measure the depth/thickness of the fan - if it's a slimline one then a standard fit fan might not fit.
