Cheap GFX Card
10 Sep 2008
Bangor, Northern Ireland
Hi guys, ive been out of the tech loop for just over a year and was wondering what the best performing card i could get for around the £60 mark. I plan on doing some high end gaming but on a budget :)I was looking at this and it seems bargainalicious. Basically the question is, what card would you buy for the money?
Thanks
I'd get a 4650, Dual chip cards aren't known for their amazing driver support, and in some games freeze altogether, unless you fancy going 2nd hand then you should be able to pick up a 4850/4870)
If you plan game on a budget i'd say get a 4850 with the mony saved from not having to buy a higher watage PSU or the 4670 and it will save you a fair few quid on your lecy bills.
