Cheap gfx to get Ryzen build up and running.
8 Jan 2007
Manchester
Got the parts to build a Ryzen 1600 build except a gfx.
Any recommendation that will power a Dell U2515H so I can get everything up, running and tested?
No gaming yet until I decide on a 1080ti or Vega but thats going to be 4 weeks before the wallets opened again.
Anything modern really! Given its a stop gap buy second hand. A 750ti is pretty cheap and you can game at 1080p low/med 60fps
get the old gt 210 if its nvidia or the hd5450 , both will support windows 10 if thats what you going to use(hell gma based and amd equivalent can run 10) and both can be had used from a fiver, shouldnt need anything more than that for simple setup and running unless you plan on doing anything beyond their capabilities
Thanks for the ideas. Picked up a gt710 for now.
Why wait when I can buy the parts as they are coming and going on offer and I can save money?
everyone has their own way of going about things, i do this even if its a much slower process as i know if i buy something particular now id likely want to change within months lol, not to say he be the same, but if it means being able to use the computer then the cheapest card you can find, is good to have spares though saving wasting money.
