cheap graphics card that works in pci express 1 slot?
23 Dec 2005
Hi all, can anyone recommend me a really cheap crappy graphics card that works in a pci express 1.0 slot. Its just for a temporary solution. I want to briefly remove my current graphics card so i can install 2*raid controllers in my pci express 16 slots and then migrate the data off one array onto another in the same machine (saves me having to do it over the network).
In the context of the OP I think he meant PCIE 1x, not 1.0? In which case OP you need a pcie 16x to 1x adapter, which OCUK don't sell. Otherwise what Gregster said!
the motherboard says PCIEX1_2 next to the socket I had in mind ! so the card gregster mentioned should fit straight off without the need for an adapter? Is this card also low profile or is it a fat monster as a low profile one would be better so i dont cook my raid controller :)
Can you use any pci express 16 card in a PCIEX1_2 slot if you have the correct adapter then?
Thanks for your suggestions.
You can plug that GPU in I linked with no issues. Get the B grade one and it looks low profile but if it sits too high, bend the fins over :)
