Cheap HD capable card
17 Jul 2006
Hy all.
I'm speccing up a media centre pc for my dad to use with his new HDTV. I was just wondering, are there only certain graphics cards that can support true HD stuff?
this one:
EVGA GeForce 7600 GS 512MB DDR2 HDTV-Out/DVI (PCI-Express) - Retail (GX-003-EA)
Is the only one I've found so far thats inside the budget that actually states anything about HD, and even then theres nothing that makes me assue that it will support 720i.
Can anyone recommend cheap cards that will pump out 720i and be fine to play DVDs on, his rather aging system atm starts bleeding whenever he downloads HD trailers.
HD just stands for high definition. That pretty much means any resolution over standard definition (640x480? interlaced). 852*640 is sometimes called enhanced definition, and high definition starts at 1024*768. 720p is 1280*720. That is what most of the tv's can output, and any graphics card from the last few years can do that resolution so they are infact "HD" cards.
Check on if he has open vga, dvi, or hdmi inputs. Cards also have HD component outs, which are the green blue and red set of video cables.
