I'm thinking of just letting it go with the am3 set up inside of it if I can sell it just to make things easier. Dont want to break the system up as no boxes or packing for stuff inside...and it's absolutely filthy currentlyWhat's wrong with the CM690?
Zalman i3 sorry, phone autochanged it and just as I'm doing a fresh build, I fancy a fresh case with a full length shroud and with the HDDs out the way as imagine this would allow better airflow/coolingWhat's your reasoning ? And whats a Salman i3
The serocool only comes with one fan so your going go have to add a couple at the front bringing it to the same cost as the zalman.
Can turn off the white lights on the zalman ? But you can adjust the fan speed on top of the case.
Zalman slightly edges it imo.
Zalman t7 comes with 2 fans according to the description , add another couple of arctic p12 pwm and it's a winner.
https://www.overclockers.co.uk/zalm...MIzrmB46D17AIVgmDmCh3ZuwhXEAQYASABEgJWg_D_BwE
Couple of fans £10 dependent on choice .So it does! Didn't look at that properly! It also has that lovely hinged door which I quite like the look of but would a couple of fans take it over the price of the i3? The i3 is also has a bit more room inside from the dimensions, not that it makes much difference but it's nice to have a little bit more room to play with
