Cheap Micro atx case?
20 Aug 2011
Hello, im looking for a new case to replace my FT03, was looking at the Fractal design core 1000 which would be ideal apart from the fact it doesnt support many hard drives, and i have 4x3.5 and one ssd. Ideally im not looking to spend more than £50 and needs to be roughly around the same dimensions as the fractal case.
thanks
Apart from the Silverstone PS07. It's a cut down TJ08, and performs pretty much the same. Still over your budget, not much room for drives. IIRC, the Fractal Define Mini would be better suited, if you don't have a mahoosive GPU. Again, not cheap. Don't know much about el-cheapo m-atx cses, maybe a CoolerMaster 430 Elite or others? Check out the dimensions of their range, but they are a bit beggar.
EDIT : Too big.
PS07 said:
1 x 2.5" Internal
5 x 3.5" Internal
2 x 5.25" External
Hey, PS07 might work for you. £62 in black somewhere else.
