Cheap Mining Rig.
25 May 2013
Kent.
Looking to build a separate rig solely for mining, and want to spend as little as possible.
I already have a case in mind, an open frame.
I will need an OS, and preferably a HDD. I have heard people say to install off a USB, but.. that confused me something silly.
Thanks. Clearance/B grade is fine.
You still need to give a budget or a hashrate target.
If you are doing this to make money, you are far better off trading cryptocurrency rather than buying into mining with a small budget.
I would go for the cheapest 60gb SSD you can find, any cheap DDR3 mobo/cpu/ram combo, a decent gold PSU and a test bench over a case. Whatever is leftover is to be spent on the AMD GPU(s).
