Cheap monitor with loads of inputs?
1 Sep 2005
Scottish Highlands
Does anyone know of a cheap monitor or tv with loads of input types (vga,dvi,coax,composite,component and scart). It also must be wall mountable. They are to be used as control room monitors. The cheaper the better. Any ideas?
Goodmans GTVL19W17HDV 19 hd tv with DVD PC Input
I have one. You can find them for about £160 if you look hard. 19" screen, has HDMI, DVI-D, composite, coaxial, multi-card-reader, DVD player, arial (sp?!)
Only a few negatives; its Power Saver can be annoying, and (very rarely) it gets out of Phase (easy to fix with "AutoSync") - plus if you're below (quite far below) it then all the blacks merge together... as in, dark grey becomes pure black.
Hope that helped.
Ungh, not again! I wouldn't really class them as a competitor, but will remove anyway... OCuK is leagues above them, and in a (slightly) different sector...
