Morning All
My OCZ 600W GameXStream PSU recently died after 5 years so I'm looking for some suggestions for a cheap replacement.
It's for my HTPC running XBMC and acting as for storage for my other machines. It consists of:-
ABit AB9 Pro Board
C2D E6600 @ 2.4GHz
4GB Ram
Nvidia 8400GS
6 x HD's ranging from 36GB Raptop up to 1TB Seagate
PCI WiFi
PCI WinTv Satellite card
Hooked up to Samsung LCD for 1080p Playback
I'm just looking for a cheap replacement, I don't know if it warrants the extra pennies for a 600W OCZ, it doesn't even have to be branded and doesn't need to underpin an overclock, everything is stock.
I may convert it to an Esx host at somepoint, migrate XBMC to a Pi then use the Esx host simply for storage and playing.
Any suggestions for something cheap and cheerful please?
ABit AB9 Pro Board
C2D E6600 @ 2.4GHz
4GB Ram
Nvidia 8400GS
PCI WiFi
The only thing I might do to this system in the future is upgrade from an E6600 to a Q6600, double the memory from 4GB > 8GB and remove some of the older HDs and swap them for 1TB/2TB disks.
