Cheap second hand alternative to D90 using same lenses?
15 Nov 2003
Marlow
I plan on doing a lot of time elapsed photos. I'd rather not use my Nikon D90 for this (eg: throwing thousands of photos onto it out in the elements), so I'm looking to buy a cheap second hand camera which is compatible with my D90 lenses.
Currently looking at D70s, but wondering if:-
1) I can definitely use the same lenses across both cameras?
2) There's a better/cheaper second hand option (camera)?
All lenses are compatible and I doubt you will find a better second hand camera on the cheap. There are cheap d40 out there but you will like the d70 if coming from a d90
There's a Nikon D50 with just over 6k actuations available from the Photographers Bag on Ebay here
It looks in brilliant condition and is only £104.99. I've used them a few times and had no issue at all.
Other problem with the D50 is getting a cheap shutter timer/controller for it to. The D70 (like my D90) has loads around for about £10. Can't see any for the D50 :(
I'm pretty sure the D50 is IR only just like the original D70.
IR only? You mean infra red like a traditional remote?
Looking around I think you're right! I can only see cable shutter controllers for the D70s! Thanks for pointing that out!
No, the traditional remote is a cable release. ;)
A used D3100 or D5000 might be worth considering as they use the same release as your D90. You'll lose AF with non-AF-S lenses but I'd expect you to be using MF for time-lapse anyway. But you could get a D200 for the same price and this would get you much better weather sealing, viewfinder, etc. plus it can share batteries with the D90.
You really need to look at Weather Sealing and Video reproduction here, I would just use your D90 and duck tape a umbrella onto the tripod, Just having it out of shot, I wouldn't worry to much about loading a lot of shots onto your D90, They're not all that exspensive now, You can even buy a D7k for £620 these days new.
