- 15 May 2012
- Louth, lincs
As tittle for a corsair 540 cooling just the cpu, 4770k.
Have bought one of the koolance single bay res as i think it will look the part with the case. Thinking that a 240 in the roof will do which will leave the front 3 fans to provide good airflow for the dual gpu's.
Would like white fluid.
I have done a loop before but spent quite a bit of money on that, so it kind of guarantees good performance at the lower end i'm not sure.
Any help would be appreciated, thanks
I'm sure you can spec those up considering your last build
