Cheapest AM4 Compatible Cooler?
5 Sep 2012
Morning
What is the cheapest AM4/Ryzen cpu cooler available? I'm just looking to test my new CPU,MOBO and RAM before I build my new WC loop just in case anything is DOA as I won't get to start my new build properly for a few weeks.
Cheers
Tom
https://www.overclockers.co.uk/arctic-freezer-7-pro-rev-2-cpu-cooler-hs-035-ar.html
This one is the cheapest I think. It doesn't use the holes in the motherboard it uses the plastic mounting clips that come pre installed in AMD motherboards which is why it's compatible since before launch.
*noo It's this one thats cheaper: https://www.overclockers.co.uk/antec-a30-dual-heatpipe-cpu-air-cooler-hs-015-an.html
To have a look at others that use the AMD clip system you can check this list under the right category: https://forums.overclockers.co.uk/threads/ryzen-cpu-cooler-information.18770249/
