my girlfriend has a w800i but the problem is she is with o2 and it has the voda live logos and everything on the menu, can anyone tell me a easy way of getting rid of them?
true you cant unlock but you can debrand the phones, you will need to download the davinci software and then buy a credit from there you will need to go on the seuniverse forums and ask for various codes or look through the tutorial, its quite simple, but make sure you back up all your phone data first as you will lose it.
However if you are looking to unlock the phone so you can use any simcard in it then you will have to either buy a specific cable or take it to one of those many shops you find in towns around the country.
