Cheapest - But Qulity PSU
5 Aug 2006
on OcUK what is the cheapest psu , for around 400watt (more is nice but not needed), all i want is one that *isnt* going to make my system go up in smoke, oh and it must be quiet :|,, got a q-tec atm and it is so loud its not even funny :| :(
^^ both the above are good suggestions.
Have an Akasa Paxpower 400w in a second rig. Its quieter than my Liberty I would say. Great psu :)
Seasonic S12 430W Silent ATX2.0 Power Supply (CA-000-SS)
£51.69 Including VAT
Might cost a little more than other brands available, but Seasonics are excellent.
I have that and the Liberty. Unless the Seasonic have updated their models, the Liberty has more connectors, I would get the Liberty. The Seasonic is a bit short on SATA power leads (only 2)
Can't speak for how good it is, but on offer this week is:
OCZ ModStream 450w ATX2.0 Power Supply (CA-016-OC)
The OCZ ModStream power supply family is the quietest, sleekest, most versatile PSU available today! The ModStream comes in 450W/520W configurations with 550W/620W peak loads; they are the ideal solution for PC-users desiring a high-quality mix of power and versatility in their system. Every ModStream is equipped with OCZ EZMod technology. This advanced cable management system allows you to truly customize you power system to utilize only the UV cables you require, resulting in optimal airflow and the coolest possible environment within your case! All EZMod cables glow brightly when illuminated with UV lighting accessories.
- OCZ PowerWhisper Technology with 120mm fan
- OCZ PowerShield PCI-Express lead
- OCZ EZMod advanced cable management system
- Supports ATX/BTX/PCI Express/SATA
- Active PFC**
- 3 Year warranty backed by OCZ’s exclusive PowerSwap replacement program.
Previously sold for £44.99 +VAT
Price: £39.99 (£46.99 Including VAT at 17.5%)
Silver Power 400w for around £25
It's shame OCUK don't stock it, cracking psus, best in the budget range by a long way.
allllec said:
is indeed my sig, if you click like
or it is [email protected] (i am allowed to post this right?)
decisions decisions..
*edit*
whops my sig was broke, i moved the image, whopsee!
you also need to remove the "http://" bit before the "mailto:
I purchased a sansung 500watt for £18 for my second machine. The PC is on nearly 24/7 and has been now for nearly 6 Months solid. It has been so reliable & quiet i cant fault it.
ah cheers vent ^,^
think im gonna get the seasonic, more than i would like to spend but its from OcUK and havent heard a bad word against them (my last seasonic was awsome lil 350watt thing and did me proud)
just need to get some money together now :rolleyes:
right, just managed to pick up an akasa 460watt paxpower for £20, very quite and nice, all braded cables, easy to use molex thingies, ahh :) cheers for the advice anyhow guys lol
