Cheapest card to "max out" Age of Empires 3?
15 Nov 2011
Hi,
I currently have an GT220 (yes rubbish I know but I dont play games often). With an E6600 overclocked to 3.4GHz and 8GB ram.
I would like to play AOE3 with the best graphical settings enabled and still no performance affected.
I am guessing it'd be better to upgrade my GPU. What is the cheapest card I could get to max out the best graphics settings on this card?
I saw this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-028-KF&groupid=701&catid=1914&subcat=
- 384 Cuda Cores
- 900MHz Core Clock
- 1800MHz Shader Clock
- 2048MB GDDR3 Memory
- 1800MHz Memory Speed
seemed pretty good? Or am I spending more than I need to for such an old game?
It is rubbish for games and I have no idea how it would do with age of empires 3. I have linked a GTX 650 bench results which looks ok in results but it still isn't great.
http://www.anandtech.com/bench/Product/681
If your budget is tight, look for a second hand 460/70 as that will do pretty well in games :)
Well my logic was that the game is 7 years old now, so a "cheap" graphics card today should have been able to handle it.
As I was wrong, would you be able to recommend a card less than £100?
I'd go for a second hand 460 or 5850 off an auction site as they can't really be found new any more, that should max it out :)
Age3:Asian Dynasties @ 2560x1440 runs on the Ivybridge IGP (HD4000) quite well with a few settings reduced.
A 5770 runs it with 4xAA flawlessly. The FPS is mostly CPU limited so more powerful graphics cards are wasted.
It's a lot more demanding if there's water being rendered as the water effects were very advanced at the time.
