Cheapest card with A8 CPU
2 Dec 2004
Under The Desk, Wales
Guys, what is the cheapest card i could use with an A8-7600 that will run most modern games like Battlefield 4 or Just Cause3? Budget i am not sure just want the cheapest possible that will allow the above games to play smoothly. My res is 1920x1080. I have 8GB 2133 ram and an SSD. Ta
That 7600 should be playable at 720p.
For a new (not second hand) option something like an R7 250 (~£57) would be the cheapest possible I would say (avg 30 FPS with reasonable settings at 1080p). Above that you're into the R7 360 / 750 Ti / R7 265 sort of range (all good options).
Finding a used one though as i cannot access MM on here :(:(
Unless you did something to lose the privilege, you should be able to. But maybe you've never requested the access? It's not like you're lacking the post count ...
I was a naughty boy years ago which cannot be forgiven it seems!
GV-N460OC-768I
This is the card that my mate has said i can have. Any good?
