Get a 6600GT for about £60 off the members market, not the very cheapest way to do it but i think it'll serve you better than something half the price that just about scrapes the minimum spec.
[email protected]
ABIT NF7-S using the onboard Soundstorm
1024MB PC3200 DDR
I've got to replace the GF3 for other games anyway, so the 6600GT sounds attractive, but she is demanding (!) a new card. So, the MM is not an option but new 6600GT's still cost a bit more than I'm willing to spend.
The Radeon 9550's are cheap but are fully DX9 compatible and I was hoping that it would offer both high frame rates with most of the gfx options turned on.
If you really want a new card a 9550 should be fine (just don't get the SE version as this really is appalling!)
I built a cheap PC around an A64 3200+/1GB ram and an X550 and that runs World Of Warcraft without breaking into a sweat - it's not all that demanding!
My mate plays serious pvp wow on a 64mb GF4ti 4200, they can be had for 15-20 quid. But i think a 9800Pro would be your best bang for buck, as you can play it maxed out at 1280x1024 with one of those.
