The new cards will force down the price of most older cards so I'd wait and try and pickup something like a second hand 4850/9800.
I was thinking of getting a 7950 Gx2 1GB and i can have it for less than £40.
Would this handle cod6 you think?
Only playing at res 1280 x 1024
at that resolution should be enough me things but i recommend to get 8800 gts g92 512mb second hand
edit: is the card for cod 6 or cod modern warfare 2 ?
COD6/MW 2
and yep it is
Same thing isnt it?COD6/MW 2
and yep it is
You dont say what you have ATM
but if you can run cod4 on max there's a good chance MW2 will run ok on medium settings from what ive heard
