Cheapest or best VFM router with bandwidth limiting
23 Mar 2008
Hey All
I was wondering what router everyone would recommend that would allow me to limit the bandwidth of certain devices. If it makes a difference the devices I'd like to limit will all be WiFi connected.
I don't mind if this is through some fancy QoS functionality, or guest wifi access with speed limiting. If anything I think a guest WiFi would be ideal as it's mainly to limit phones and streaming boxes - and guests can be given the guest password only, keeping all my network shares safe!
Any recommendations? If will need to be compatible with BT/Plusnet fibre.
Thanks!
You can do all that by turning off your WiFi on your ISP router and buying a Uniquiti AC-Lite Access Point.
Cheapest router that can do this is probably something from Mikrotik
