Been wondering this for a while myself:
Can 2133MHz RAM work on a motherboard that doesn't say it 'supports' it in the specs ( itonly goes up to 1866MHz)? For example, in RJC's build the board says it doesn't support it yet he's put in 2133MHz RAM? Is it pot luck if it works or not with the board, because I've seen similar specs before and am curious to know the answer![]()
The ram will default to the lower speed, you may get it to work at the higher rated speed by overclocking the system.
