cheapest pc
12 Jun 2013
I was wondering if we could make a pc that was pretty bada** for about £300 I'm looking for everything cheap but buyable from overclockers ie I saw the £31 case then so on please help me. I wanna see how cheap I can build a pc that can play most games even if on low settings.
i think your better off saving, for £500 you might be able to actually get a decent AMD built that can play most games on decent settings (ie not low)
or even better take the case and psu out and spend £500
Budget is £500 then? Dont need monitor/os/mouse/keyboard?
YOUR BASKET
1 x Powercolor Radeon R9 280 TurboDUO 3072MB GDDR5 PCI-Express Graphics Card £179.99
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £110.99
1 x Crucial M500 240GB SATA 6Gb/s Solid State Hard Drive - (CT240M500SSD1) £89.99
1 x Asus M5A97 LE R2.0 AMD 970 (Socket AM3+) DDR3 Motherboard £55.99
1 x TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (TLYD38G1600HC9DC01) £49.99
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
Total : £516.54 (includes shipping : £8.00).
You can install windows via USB and i cant really see the use of cd drive to be honest, 250gb ssd more than enough space for starting. i currently only have 120gb as my HDD of 500gb broke. You should be able to play most games at 60fps without any problems
I don't need the cooler either I'm gonna step it up to my budget sorry for the pains of this but I'm grateful of you spending your time to do so my budget is £1500 I have a case heatsink and psu. and all the modcons :)
lol, next post its gonna be of £2000 ;). I think you need to sit down and think about what you actually want 1st, do you have in mind what games you want to play, do you have a preference between amd or intel / amd tends to be more on the budget side of things. Is this mainly a gaming pc or do you have any other use of it and etc.. the more specific you are the more we are able to help you.
What case. heatsink and psu do you have?
whats your personal pref
if your on a budget = AMD, if you have money to spend and usually have a budget over £800 or so Intel. I however like AMD as i think its great value for money, love my fx 8350!!!! I also dont like to spend more than what i would actually use it for.
But all of this is pointless, if your budget really is £1500 then its Intel all the way and im sure one of the more experienced members here will post you a very good spec
As you have everything else you need apparently, this will let you max everything for the foreseeable future. Massively overkill IMO but its you cash.
YOUR BASKET
2 x OcUK Geforce GTX 780 3072MB GDDR5 PCI-Express Graphics Card £359.99 (£719.98)
1 x Gigabyte G1.Sniper 5 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £259.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £239.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £119.99
1 x Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD £79.99
1 x Kingston HyperX Beast 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit (KHX24C11T3K2/8X) £45.95
Total : £1,475.48 (includes shipping : £8.00).
