I used the H77 to keep the cost down. Personally I'd want a Z77 mobo like the asrock. The H61 mobos don't do sataIII so depending on your SSD it could be wasting a lot of the speed on sataII
I used the G840 aswell to keep costs down. It's gaming performance is very close to an i3 2100 whilst being much cheaper. If you had a Z77 mobo you could look to upgrade to an i5K much later and overclock.
The 7850 is excellent bang for buck. The example I have used has a 3 year warranty, clocked higher than the cheaper sapphire card and importantly has 2GB of VRAM. These cards overclock very well so there is more performance to be had if you so wish. There are plenty of quality free to play titles on the horizon, it makes sense to pay a little more on the GPU front to cover yourself for the future. You could have course sell the included games to recoup some cash if you want to.
You are welcome. What you have to remember is that because of the layout of the mini-itx mobos, tower heatsinks can be a bad idea. Depending on their size they could possibly overhang the PCI-E slot for the GPU
If your aftermarket cooler doesn't fit then just use the retail stock heatsink. You will see that many builds using the prodigy are watercooled or indeed use a closed loop cooler.
