Cheapest system going!
9 Aug 2004
Milton Keynes
After a small PC to go into TV cabinet. All I want/need it to do is play videos (up to 720p) and music via HDMI connection. Also a 1TB HDD. Got a XP license so just need hardware!
Cheap as possible really unless its worth spending a little more.
Did look at the sticky builds for £400 however the picture doesn't show up!
Also if possible be good at encoding into DIVX files.
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ)
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive - Retail
Asus M3N78-VM NVIDIA 8200 (Socket AM2+) PCI-Express DDR2 Motherboard
Antec NSK 4480B Mini Tower Case - Black (380W Earth Watts PSU)
AMD Athlon 64 X2 Dual Core 5000+ 2.60GHz (Socket AM2) - Retail
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series
Sub Total : £290.94
Shipping cost assumes delivery to UK Mainland with:
DHL Select Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £9.99
VAT is being charged at 15% VAT : £43.64
Total : £334.58
My 2p, more than enough power for your requirements, cool running dual core at stock. Should be quiet enough but not silent. Onboard everything from the mobo with HDMI and smooth HD/Bluray playback etc all the encoding is done onboard. Also added a Bluray DVD-Rom, you did not specify but I figured its there for futureproofing and incase you want to play Bluray movies over HDMI etc.
Case may not be to your liking and a little to large but with the mobo being M-ATX you can change this for anything that takes your fancy!
Oh and knock a tenner off that price as you should get free shipping for being a dedicated forum member and ocuk customer :p
