Cheapest way to get a phone line installed + ADSL connection..
Don
21 Oct 2002
Parts Unknown
Mum wants to get wireless in her holiday cottage (as in, one she rents out to people)
Instead of sharing her house connection, the best solution is to get it's own landline
Her connection is limited to 512kb (really damn far from the exchange, lucky to get BB at all)
Basically after cheapest line rental, with basic internet, I'll lock it down via router / opendns
Comments?
Do not live on the mainland but I heard people posting of data lines only for cheaper than a voice/data line installation/rental.
Might be worth looking into that if its purely for DSL.
As you're in the sticks you probably have no LLU services so your only real option would be:
BT Line (Install £125 then £10.50 / month rental) + Really cheap ADSL provider at £15/month ? Maybe even use BT?
At the moment I do not think it is possible to get a BT line installed for just DSL purposes and pay no rental to them for it.
Unless its physically impossible to share the existing connection I dont see how you can get a new landline without paying a significant sum in BT install fees and a chunk of monthly line rental plus monthly broadband (maybe sky or talktalk or simialr for the rental and a package). cottage would have to be making a lot of money to cover all that.
there used to be some sattelite broadband services if you board the hardware ?
By the time you've bought / leased the hardware a reasonable (say 512/128) satellite connection will likely cost as much as or more than a fixed line solution.
so looking at roughly..
£125 one off
then £25ish a month?
that will easily pay for itself, as currently the odd customer is turned away because they wouldn't be able to work whilst on holiday
also, is there a way to set your router to keep telling opendns what it's IP is? -ie, without needing to use software to make sure opendns filtering is always used...
hmm tiscali seem to do £15 a month, including line rental
Apparently Post Office do a new line for £100 with the bonus of not being tied into a 12 month contract like you would be with a BT install.
I got a bt line reactivated by the post office cos it was cheaper. their sevice has been good and i can get adsl from any isp that offers it at my exchange on a bt line. definately worth checking if they can provide a line.
